01.17.2007, 12:40 AM
Thanks jhautz! I like the interface better too. Although, this started as a single page and it sorta grew as I just tacked on more stuff. It did need an overhaul.
Originally Posted by pinolelst
A bug IMHO..I tried inputting values for a xxx-t 2.43:1 tranny ratio 16 tooth pinion and 86 tooth spur 11.1 volts (3s lipo) mamba max 7700 kv motor and got a warning that my motor might overheat due to a 40k rpm limit on brushless motors and no top speed estimate was given...castle rates their motors at 65k and even then I'd exceed that but rather than get a warning and no output why not have the warning and give the user the option to proceed with the top speed estimate??
We all know there are a few of us who throw the warranty cards away in the interest of destructive testing for empirical data for the masses :005:
hope this helps
pinolelst
Thanks for the feedback! First of all, crazyjr is right, it will still figure out the values, it just warns you that the rpm is over the recommended limit.
Next, which page was this in?
If it's the "top speed estimator" or the "solver" page, then you have to select the motor from the list because there are seperate max rpms based on manufacturer ratings. If you type in "7700" the program uses the baseline 40k rpm as the limit. The program does not try to look up a matching motor since that would be a possibly incorrect assumption. I just tried it by picking the MM 7700 motor and it said it exceeded the 65k rpm limit, which is correct. But it still displayed the results regardless.
If it's still giving you something you don't think is right, post a screenshot of the error along with the values chosen and I'll see what I can do to correct it... or at least explain it.
