fiero_silva
01.21.2007, 02:16 AM
Originally Posted by MetalMan
Are your battery packs stick packs or side by side?
Have you calibrated the throttle with the endpoints on your radio set to full?
If all else fails, you can contact Castle on Monday and ask them what might be going on.
Side by side packs. EPA is set to full.
Originally Posted by BrianG
The 7700 is a very hot motor. That would probably be a 3 or 4 turn motor using the kv ratings of similarly sized S motors. Therefore, your batteries are probably unable to provide the current needed to get that moving under load.
That seems like a logical explaination, however I am experiancing no cogging at all... I would expect to see some cogging at a minumum if the batteries were not good enough?
What would one recommend for a lipo-pack? I'd like to run 3s at a minumum.......
Originally Posted by Bomb-Proof
what temps is it running, how good are your packs?
Just for kicks, I tried 14.4v just a few minutes ago, Iirc motor was 110ish, speed controller was 165. Speed is better, but definatly nowhere near what it should be....
