AAngel
01.21.2007, 03:29 AM
I've been playing around with the Mamba Max systems. I'm running a Mamba Max 7700 system in an RC10T4 on 3S Lipo. I've learned a bit since I got the system and would have taken a different route, if I had it to do over again.
The biggest problem that I had was that the esc kept thermalling. The motor was always cool though. I wound up having to go with a 12T pinion and the 87T spur to keep the thing from thermalling and still be able to get a good gear mesh. I also went from a 3S2P 8Ah pack to a 3S4Ah pack to cut the weight. The last thing I had to do was to run short tires (Speed Hawgs) with duct tape on the insides to keep them from ballooning and messing with the gear ratio. The setup is fast. Really fast. I wanted something fast, but didn't want a Jato. Everyone had a Jato, so I built this. Jatos (stock or modified) don't have a hope of keeping up. I guess that I can safely say that it does at least 60 mph.
With your Jato conversion, you have a few hurdles to get over. First, the Jato weighs more than my T4 does. You're also going to have to get some decent batteries. Lipos, or some sort of battery packs based on lithium chemistry are your best bet.
The absolute fastest Mamba setup that you can go with is a 4600 motor on 4S Lipo and gear it. I'm just not sure of how this will work out in the Jato because of it's weight. From what I'm understanding, you might want to consider getting one of the Feigao "L" motors and gearing it up. That might get you what you are looking for.
