Henry8601
01.21.2007, 09:12 AM
Yup coolhandcountry is correct, I would be running them in a wild dagger, hence the need for two separate systems, very similar to dagger thrashers project which is somewhere on this board. It seems to be a little difficult finding specs for these motors as noone really seems to know what spec LiPos are actually required. I will probably be going with one maxamps 8000mah 3s2p packs to supply both systems.
# 20C Constant(160 amps)
# 30C Sustained(240 amps)
# 50C Burst(400 amps)
should be enough shouldn't it? could a 4600kv motor spike to 200A? It seems like a hell of a lot really :026:
