glassdoctor
TEAM FUSION
glassdoctor's Avatar
01.22.2007, 11:13 AM
That's why I asked if hte tires would balloon... trying to tell if its' slow because it's way overgeared, or if it's just not hitting a descent rpm. Yes, the tries should balloon way up on 7.2v and they should about come off the rims on 14V
So something ain't right.
If the esc is programmed with the radio at 100%, it won't matter if you set it to 125% and re-program it. It should be exactly the same.
Just check the leds on the esc as see if it's hitting full throttle... shoudl be a (green?) led light up at full throttle.
