maxxdude1234
maxxdude1234's Avatar
06.16.2005, 03:52 PM
Originally posted by Rannick
the 17 V should be the output of the motor?
Its the voltage from the batteries or other sources.
and what is this Ampere line from?
The Output parameter are only the Um and the Ncm
Hmm dont understand this and u only answer the HV would have the best runtime, but why? can u pls explain it a bit more... and can u explain the graphic?
I would be almost 100% sure the power would come from a very expensive digital power supply. That way they can easily alter voltage and current very precisely.
The Um output is the rpm of the motor (22432), and the Ncm is the torque (17.93). Power is directly proportional to rpm and torque. Therefore if torque is high and rpm is low, overall power is the same as if torque is low and rpm is high (bad explanation,but you should be able to understand...)
