06.16.2005, 04:53 PM
In fact, all the (electric) motors are the exact same, when you calculate them back.
It is the power that they take, vs the power they throw out (efficency) all the motors give the same amount of torque and watts if you calculate it back to raw numbers..
If you have got a brushed and a brushless setup that throw out the same power, in most of the cases (99,9 percent) the brushless setup has got higher efficiency, so it will run longer on the available energy. if they are fed with the same amount of energy the power output of the one that is most efficient will be the highest. (if mechanical losses on both vehicles are the same)
One thing is also nice to know about brushless motors;
the difference in torque from one and another motor from the same serie, but with different winds, is allmost the same, when compared to eachother.
And Rannick;
Please notice, that you linked to a picture directly from BK, if you can host it yourself, please do so. And if you can't please let me know.
