jhautz
jhautz's Avatar
01.25.2007, 02:06 AM
IMO. The L will be enough motor, but the XL will run cooler and have a little more kick to it, so XL gets my vote. I would also say that the XL would be a better chioce to run with the Mamba Max also. I have found that the MM runs better with a 2 pole motor than it does with a 4 pole motor like the Neu. Castle is working on an update for the MM to fix that, but for now I still think the XL will be a better match.
As far as the mechanical brakes go, I think you are wasting your time. Real estate is preciuos on a buggy chassis and your buggy will not be that heavy relative to a MT and I dont hear of people having issues with the motor braking on the 11 lb revos and maxxs. So your 8.5 lb buggy should be no problem.
to make it...
or break it...
Silent...But Deadly
