01.26.2007, 07:26 PM
Yes, lower Kv generally permits higher voltage which in turn results in lower current.
High current is an enemy of efficiency. Ohms law shows that the voltage drop over a given resistance is lower for less current drawn. ie. if you are pulling alot of current, you are loosing more power to circuit resistance. This is why power distribution is done at high voltage.
