GorillaMaxx360
GorillaMaxx360's Avatar
01.27.2007, 12:22 AM
i was messing around with my cvds and knuckles and i got an idea and it worked it turns out that i wont need to buy new knuckles, bearings, and diff cups for the tsais cvds to work i looked at the cvd and the ball cup there is a little bigger size in the cvd ball part but not much. So i will grind down the bigger ball intill it fits into the stock hb diff cup. I will then be able to use the stock maxx non 3.3 just emaxx knuckles. How you may ask (becuase the revo tsais cvds have a big hump on them where the axel is to go into a revo knuckle) i was testing around and i figured out that if i remove the first bearing (bearing clostest to inside of the vehicle not the one on the outside of the knuckle) i have the same size hole that the revo knuckles have to allowe revo cvds. It is kind of hard to explain but it works so i will be able to fit this cvd problem in no time with no moneyh being spent i will grind the cvd ball tomarrow and get pics asap.
