Aragon
01.29.2007, 10:00 AM
Originally Posted by joeling
In addition, a Lipo under load is likely to drop some voltage. From my limited expereince looking at my eagletree data logger using some Kokam 20C cells, I see something like 3.2V per cell. If one is to use 8S under load, the total voltage will be approx. 25.6V. Is this logical ?
8S 4000mah capacity should be similar to 4S 8000mah with less losses due to heat. that's waht I want to try out next.
I plan to run 8S too. I hope the cells don't drop to 3.2V/cell. I guess it depends on the cells. I hope to get away with running 8S 2100 mah, but we'll see if that works out...
What do you think of the MGM 16024? You said in another thread that you fried one of them and I was curious if you found them to be problematic...
