Thread: Which Lehner
neweuser
neweuser's Avatar
02.01.2007, 01:35 PM
Originally Posted by glassdoctor
What buggy are you doing? You can fit a Kyosho gear on most of them. Plastic is a very good idea... and it's way cheaper and easier than using hardened gears at $20+ a pop. Some have still destroyed the hardened ones with BL. I never ran a steel/steel gear.
I always forget about the 4mm thing with the Lehner. Hmmm score a point for Neu. Besides being the same as most other motors, the 5mm gears are much easier and cheaper to get.
And don't forget that with the Neu, you can use 5.5mm connectors.
