GorillaMaxx360
GorillaMaxx360's Avatar
02.05.2007, 05:57 PM
i like the look of the non extended bodys if you use a wing that means that is less you have to cut out of the back end of the body to get the wing to fit (But this does not apply in your situation in your situation if you go flm extended will do you good)
