02.06.2007, 10:28 PM
Well the lehner motor experiment is on hold, till i figure out a problem. It seems that either i have it geared wrong, bad reciever or the batteries are not up to snuff. it will go foreward but sort of like a creep till a certian point then it will wheelie like crazy, like the esc has a timer or something. My thoughts are, that its either the batteries are not strong enough for the lehner, the reciever is bad and can't handle the interference or its overgeared. If it was overgeared, it would be held back all the time (brushless doesn't have a powerband, does it). The reciever is a 75 mhz JR rs300 and i have had troubles with brushless and JR recievers, so i'm looking to change up recievers and see if that helps. I got a couple LIPO packs coming from maxamps(7.4 3300mah and 11.1 2200), so i will see if the batteries are the problem. Hpoefully i can figure this out and report back. BTW the lehner is a 1020 11turn with a KV of about 5400
