02.09.2007, 08:06 PM
Originally Posted by jhautz
If your shock cups are rubbing on the slidders maybee a small washer between the shock mount on the arm and the hollow ball at the bottom of the shock to move it out just enough to clear the slidder.
I was going to suggest the same thing- but maybe used a small shim or two at the top & bottom of the shock to space it off the mounts- should clear the inside of the arm and slider shaft then. Give it a try at anyrate.
