02.10.2007, 01:03 PM
Ah, I see now. So, the end rubs on the shaft if it isnt shimmed, and if it is the spring rubs against the back-inside edge of the arm.... Do you have a dremel.........
I cant see any possible solution other than to enlarge the opening in the upper a-arm, or to use slimmer springs/shocks. You be buggered otherwise young'un as they say.
