Batfish
Batfish's Avatar
06.20.2005, 10:18 PM
I've put a few pictures up in the gallery tonight:
http://www.rc-monster.com/coppermine...s.php?album=38
Mike - the gallery is limited to 1MB for pictures? It wouldn't let me upload any more.
I actually got the brushless MGT running tonight :)
I first ran it on six GP3300 (the pack you see in the pics) to make sure I had everything set up right, then switched to one 8-cell IB3600 pack. With 6 cells it moved at about 10-15 MPH, I'd say. with the 8-cell pack, I'm sure it was over 20, but not by much. At the end of the 8-cell 3600 pack (10 minutes or so) the MGM 12012 was 115F and the Feigao 8L was 120F.
The truck didn't get enough RPM on the ground to auto-shift into second gear, but it would do it while I had it in the air. I've got to get into the tranny and adjust when it shifts, or see about getting it stuck into second.
As far as my braking concern, it turns out that the MGM uses the double-pump brake method, which means it won't go into reverse until you let the throttle back into neutral and push reverse again. So, as long as I go right from forward to brake, the motor just stops and the brake servo does it's job. If I'm coasting in neutral, the motor will spin in reverse when I push on the controller. I'm sure this isn't good for the motor since there's no real load with the tranny just spinning freely, so I'll just have to be conscious of that while I'm running.
I was using my 15 tooth pinion, so I'm thinking of going with the 16 next since the temps were so stable. I don't recall what the stock spur is on the MGT, but I know there are delrin replacements from 47 to 52, that I've seen.
Now I just have to come up with a permanent motor mount and a good system for mounting the batteries. It looks like velcro around the rock guards will work great, at least for now.
Joe
Electronics run on smoke... if you let the smoke out, they stop working.
