Procharged5.0
Procharged5.0's Avatar
02.13.2007, 01:01 PM
I'd go for the Great Assembly bulk kit. (See Pic) They are $95 vs $75 for the Fastlane machine versions but come with great bulkhead braces, are drilled for easy access to the shock tower bolts, and the machine work is better than FLM's.
I have a set of GA's in the 7075 aluminum and they are excellent! Nothing tougher! I also have their 7075 diff cases and 3mm Ti Skids. (See Pic)
If you can afford the FLM combo bulks they are very nice and provide a diff case upgrade as well.
That being said the FLM combo bulks are the best overall value with the GA's right
behind.
Name:	GA Bulks Web.JPG
ID:	2415   Click image for larger version
Name:	GA Bulks.JPG
