Originally Posted by suicideneil
Yep, you're quite right. I just got the box down from the loft and had a check- forgot what it says but I'll have another look and follow that as a guide. I forget that the emaxx drive line has a higher overall ratio than the TXT-1, hence why the 11/72 sounded a bit low to me, but then it has fewer reductions in the diff- its all groovy. Havent received a reply to my email that I sent 2coolrc so they will be getting another stern one, other wise they'll be in trouble...
Glad to hear! The little things are what I miss at times too! LOL...that gearing guide should be very useful. Also, if you are still running hot, you can change the gearing and use a fan on the esc. Mine unfortunately ran very hot all the time. I could only do two good speed passes and the esc would thermal, but others here have had good success with the HV, so good luck to you. Personally, I would sell the HV and get a sensorless system, but that is jsut me....the HV is nice due to the fact that it's a drop in system.....but I'm sure when you get the hang of the HV you may want more, I did anyway.:027:
