neweuser
neweuser's Avatar
02.16.2007, 11:30 AM
Originally Posted by jollyjumper
whats the difference:032:
They are pretty much the same. Warrior Micro....etc.
As far as 14.8 on 10xl, you do not want this as the volts are too low for that KV rating. 14.8 on 8xl would not be bad at all. The acceleration would be good. 14.8 on a 10xl, the motor would be trying to draw too much. The volts don't have teh "punch" they need to push that low of a KV. Keep in mind the formula with volts and KV calculation for RPM's...14.8 would not be that great on a 9xl either unless you bumped your gearing up. A 10xl definately would be a lot for the 4s to push good.
The top end should be pretty decent and should stay controllable. You can go 5s and the motor (10xl) will be more than happy. This is what I run on mine and I have good temps and a great dependable system.
The li Saver will automaticlly cut off for you when using the lipo, just wire accordingly (like ubec kinda) and you are golden.
