glassdoctor
TEAM FUSION
glassdoctor's Avatar
02.16.2007, 02:53 PM
I'm thinking I sould try a 5s pack of these new cells and drop the gearing in my buggy/truggy. I'm curious to see how much the runtime is affected.
At 4s, the 5000mah may barely make the 20 min mark, but maybe I could drop the mah per minute just a bit with a lower gear/high volt. I'm not sure if the gearing will offset the potenial of higher current from the higher voltage.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
