Plettenberg Powered Revo
Compliantguy
Plettenberg Powered Revo - 06.21.2005, 09:41 PM
Well, here it is! I'm almost completely finished with my Plett MAXXimum powered Revo. I ran it for the first time tonight, and WOW does it scream!!:D I've got some refining to do on the battery tray, but that's about all that is left.
I custom made the motor mount from 6063-T5 2" x 2" x 0.1875" aluminum angle. I used the rear factory motor mount bracket to support the shelf that the custom motor mount is mounted to. The battery trays are cut from an E-Maxx chassis and mounted on a shelf made from 7075-T6 0.080" aluminum clad. The Schulze 18.97 mounting shelf is made from 0.125" ABS plastic and is mounted using the rear shock mount with spacers and longer screws, and the rear body mount.
Here is a picture. I will post other pictures later.
