auto2
06.22.2005, 10:47 AM
under is the FIX! thanks.
I had to raise up the upper shock mount cause the ft tie rod was binding. so now I have less droop but the bump steer is under control.
have to get 4 conical washers to put between the tie rod and the arm so it doesn't bind but this way is 200 percent better than before. Or maybe a rod end with a longer metal piece.
