Thread: My Rustler
My Rustler
B15
My Rustler - 02.21.2007, 04:00 AM
Heres my rustler:
Its powered by a mamba 4600 on a maxamps 4s 4Ah lipo. I use a futaba s3305 to steer, and a 3PM FM and novak xxl to control it. It also has jato arms all the way around, jato rear hub carriers, front aluminum stub axles, and c hubs, duratrax evader bx graphite steering knuckles, and maxx driveshafts. As for aluminum, it has an FLM trans case, bulkhead, front bumper, and shock towers. The trans has been mounted backwards on the stock chassis to move some weight forward to control wheelies, and to lengthen the wheelbase by about an inch. Combined with the backwards mounted front jato arms and the rear jato arms, the truck is about 2 inches longer than stock, using the stock chassis. The trans has an RC monster steel idler gear, an RC monster steel/ aluminum differential, an XL5 slipper, and drilled out 12mm hexes to fit the jato wheels on the 6mm maxx axles. I use a Proline desert rat meant for an Emaxx, and Jato 2.5 wheels with anaconda tires.
