02.22.2007, 02:05 AM
Well, as you know, runtime depends on a lot of factors, but with all else being equal, I could use the 2.5d and gear up and get the same runtime and speed as what I have now because the motor would be loaded more.
What I was shooting for was about 35mph for track use. With all the gearing (standard buggy diffs, 46T spur, 14T pinion), and with 4s batteries, I chose the motor that would get me near 35mph, which was one with a kv around 2000rpm/v. Since this motor spins faster, I'll probably get a smaller pinion to compensate. This will reduce the top speed closer to what I want, help unload the motor a bit, help runtime, and keep things cooler.
I use 4.25" as the tire size.
And yeah, I'll post runtime. But it will be closer to actual race time before I take any serious measurements. That's assuming I get good enough to even try racing this year.
