neweuser
neweuser's Avatar
02.22.2007, 11:49 AM
A bec is a battery eliminating circuit and only allows so much voltage. A UBEC converts the voltage from your batt pack to send 6v to the rx, thus eliminating using a rx batt pack.
With disconnecting the bec circuit and running the ubec, you can run a higher voltage at cooler temps through the esc without frying the bec in the esc...make sense? lol
