Thread: Lipo questions
lipomax
02.03.2005, 01:34 AM
Get the polyquest packs. I have the 4s3500 packs and they're about 7 cells worth of subCs but can delivery about 1 HP continuous. For stock emaxxes, get the 4s3100 packs. They fit in stock trays and can handle 12C continuous and 16C for 10 second bursts. You can get 4s3100 and get two and parallel them for 6200 mah and peak out around 100 amps w/o too much probs. Great for run time and light weight. I went with 8s3100 and went with a slower motor to lower amperage, reduce heat, increase efficiency. Always use the highest voltage possible, get a slower motor and you don't have to worry about heat again... plus more run time.
