Serum
Serum's Avatar
03.01.2007, 01:25 PM
The feigao's don't come with plugs; the BK wanderers come with 5.5mm plugs.
My advice is to ditch the plug and make it a direct solder. This can be done by using two 4mm female plugs and solder the wires in both ends. (you can make them shorter with a dremel)
The mamba uses 4mm plugs.
For series/paralel and other 'connecting' info, check the 'rc calculations' link in Brians signature.
