pinolelst
03.01.2007, 04:29 PM
Originally Posted by BrianG
If you direct solder, you might want to make sure your motor spins in the right direction. If it spins the wrong way, swap two of the wires. Once you have it right, then you can solder them permanently and heatshrink it.
Oh, and instead of using the 4mm connectors as a direct solder solution, you might want to try these instead. Just cut the plastic jacket off the inside connector and solder the wires in each end (don't crimp). They're cheaper and fit the wire better so there is less solder needed. Either way works though.
I thought you could reverse via the PC interface but I just plugged in my MM controller and a CC phoenix airplane controller and the reverse option only exists in the phoenix airplane controller.:024:
I think that would be easy enough to add and wonder why they don't already have it in place ??
pinolelst:007:
