glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.02.2007, 03:05 PM
If you could get Mike to put some 4mm connectors on the 8XL, and Deans on the MM leads, with leads for the ubec, you won't have to do any soldering. It should be drop-in ready.
Can you handle velcro? lol...
Sounds like you need some flux or rosin core solder.. and need to clean the part you are soldering to with sandpaper or steel wool, etc. Then the solder will stick... flow... onto the surface.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
