03.02.2007, 10:52 PM
Someone else with experience on using the MM on a heavier truck will have to chime in here, but I think anything under a 9XL will thermal eventually, but that'll probably be too slow. Gearing up to compensate for speed will just take you back where you started temp-wise due to the added load. If you're handy, you can try to fab an added heatsink if you don't want to use a fan. Just my $0.02.
