Thread: Which ESC?
glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.05.2007, 03:20 PM
The MGM120 that I have has the issue where it applies brakes to slow the car when you let off throttle, rather than just letting the car coast...
If you go from throttle immediately to neutral, it doesn't apply brake. BUT, if you go from say full throttle to half throttle... it uses full brake to slow the car to that speed.
That's retarded and makes racing impossible. Maybe they will fix/replace it for me but I havent bothered with it yet.
It's supposed to be fixed as far as I know, but they also said it was fixed when I got mine. Obvioulsy it wasnt.
It should be a simple software tweak so I can believe that it's been fixed by now.
Other than that it's a pretty smooth controller... zero cogging and throttle feels ok. Nothing awesome, but very drivable. Also it has not let the smoke out even with a few thermals etc. I think 120A is overrated though.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
