MetalMan
MetalMan's Avatar
03.06.2007, 10:20 PM
With the same power output, a higher voltage setup with the appropriate motor will have a current draw that is less than half of a lower voltage setup with an appropriate motor. With higher voltage comes higher efficiency, so for the same power input, a slower motor with a higher voltage will put out more power than a faster motor/lower voltage setup.
