glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.08.2007, 02:03 AM
Yep... I had to put new holes in the chassis. You should see how many holes are in the 777 chassis.... I did two different layouts on the same car, lol. But it works great...
If you move the diff over a bit to center it up the driveshafts will be fine. I need to modify mine though when I moved the diff forward. i used a truggy piece for the rear driveshaft. It was a hotbodies lightning stadium rear axles I think.... longest one I could find. Then I shortened the front dogbone to the correct length, homemade syle :)
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
