glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.08.2007, 03:04 AM
I used an airbrush to do some highlights and shadows, like under the 'flames', where the colors break, and in the body creases at the rear of the body, etc.
I used the airbrush for the silver too... and rattle cans for the white, blue, and green..
Actually this body is sort of a mix of all my normal paint jobs... an experiment of sorts. I didn't like that it looks like two differnet schemes stuck together.
I used to do white flames on blue. Then I did a couple silver bodies... then went bright with the neon green for all my cars. This was an attempt to blend them all. :D
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
