03.10.2007, 05:46 PM
Yup, 44/16 with a typical buggy rear/front diff ratio of 3:308 is 9.097:1. In a front/rear diff, the ratio comes from the pinion and ring gears. In a center diff, the spur and motor pinion take the place of the ring and pinion gears, so there is no additional ratio in a CD. Buggies generally have low ratios because there is no tranny.
Revo diffs are 2.846:1.
Buggy diffs are 3.308:1.
Emaxx tranny is second gear is 1.722:1
Total is 5.696:1 using buggy diffs without the spur/pinion ratio.
Total is 4.9:1 using Revo diffs without the spur/pinion ratio.
Depending what spur you use, it should be quite easy to get final ratios from 10-17:1.
