skellyo
skellyo's Avatar
03.15.2007, 11:21 AM
Originally Posted by elegal
I want to be able to use them in an emaxx a well, plus I like the extra protection provided by the trakpowers.
They would be staggered enough to allow the bottom battery to be plugged in.
I would wire the harnesses together just like one big pack, the balancer and charger should see them as one large pack, and i shouldnt have any voltage problems if i discharge them at the same time in the same car.
I would just need another balancing cable to balance my other batteries.
Sounds logical to me. The only thing you should need is an extra Trakpower balancing harness so you can custom make an adapter for the V-Balance for 4S. For me, since I have two ICE chargers, I just ended up buying two of the V-Balancers that included the Trakpower harness.
