Finnster
KillaHurtz
Finnster's Avatar
03.15.2007, 01:49 PM
Originally Posted by david lamontagn
Thank you for all your repply. But i'll wait little time before order a new motor.
To the place, i'll try my Feigao 540C 8XL that i've on my LSP conversion and put it in this Jato and gear it with a 26 pinion, and change the original tires for the moab, they have 1 inch more on total diameter than standard 2.2 stadium truck tire.
So considering that the rpm/volt of the 8XL is about 2083, on 14.8 volt, with the single speed convertion, gear 54/26, and with the extra inches tires balloning, i would hit about 60m/h + if i put all this number on the r/c calculator.
An 8XL?!:030:
I weep for your tranny. Are you going to be able to find 5mm pinions in that size? If you get it worked out, please get a vid :P
