Originally Posted by ozdave
Awesome! Thanks for the pics and detailed explanation suicideneil. Very helpful.
I think i will do as you say and buy a few different pinions and have a play.
With an 8xl on 16 cells, I probably would not run the 18T pinion unless you plan on running a fan on the esc. A 16 will be about perfect for you. If you are looking for 40mph on 14 cells, go with a 7xl for sure and gear it 16T. I ran my 9xl on 16 cells with an 18T and it ran too hot even for that. That was with using 1/8th diffs as well. So an 8xl on 16 cells with a 16/51 would be about perfect. Or, 7XL 16/51 on 14 cells....
