Originally Posted by squeeforever
Personally, I don't think that would be the best connection. I would twist it really tight and then either enlarge the hole or take a razor blade and cut a few strands off at a time...
Cory what i ended up doing after talking with brian, was strip the 12g wire down to 14g . Then i tined it put in the plug then i soldered it.. You should hopefully have your package tommorow,.
