Thread: So far so good
03.21.2007, 11:55 AM
Originally Posted by RC-Monster Mike
The battery tray is a Kyosho twin force tray that I modified slightly. A little dremel work and a couple piece of plastic to space the packs out and secure the gorilla strap to(and a 3/8" thick piece screwed to the chassis using existing holes that the tray is then screwed into to provide a flat surface and clear the mud guards) and whoila! It worked out pretty well.
Thanks Mike. That mudguard-clearing spacer sounds a lot like what I did in my buggy. I hate having any weight mounted on the relatively flimsy mudguards and the spacer thing works well. What material did you use? I used some 19mm wide x 10mm tall x whatever length plastic/nylon stock. It is light and self-threads nicely.
