MetalMan
MetalMan's Avatar
06.27.2005, 10:14 PM
The Warrior 9920 actually isn't a Lipoly safe controller. It has no cutoff like the MGM controllers do. Also, the Warrior 9920 has no BOAT mode, as it is a car controller. The Warrior can be programmed through a USB or PARALLEL cable, but its programming options are limited (mainly changing the motor timing). For these reasons in this post, I consider the MGM controllers to be superior to the Warrior controllers.
