glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.26.2007, 10:23 PM
Originally Posted by captain harlock
Then, the idea is to fill up the gap between the tire and the insert, right?
I should try it very soon.
Well not really... the ides is that the tape won't stretch. So when the tire wants to stretch and balloon out... the tape can't. If the tape is stuck good enough to the trie, it will hold the tire at it's normal diameter.
Just like if the tape was on the outside.. you can see how that would stop the tire from ballooning.... same thing if it's on the inside, assuming it's sticky enough to stay stuck. :)
Stretchy tape wouldn't work... it must be a duct or strapping type...
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
