SilentMonster
SilentMonster's Avatar
03.28.2007, 03:55 AM
Originally Posted by lxmuff
.I’m almost done with my new 8ight with a 1512 1.5D Neu and I’ll be using the MM.
You really are using that motor? What volts are you running? There is nothing wrong with running that motor on 4 or 5 cells. It can handle it. It will be faster than all get out. It just seems the general consensus around here is to use a much lower kv motor ie. around 2000kv. Now I've gotta come to a race just to check it:027: out. I was planning on using the 1515/1Y or the 1512 2.5D.
"MAKE EM CRY"
