Kraeuterbutter
03.29.2007, 08:33 AM
my setup is 5s and 4400mAh batts..
here a diagramm of my power-consumption..
motor-rpm-max is around 30.000rpm
--> speed (calculated from the gear-reduction) should be around 55-60km/h which is already nearly too fast for my driving skills on our relativly small track
on that graph i got way too much motor-temperature :013:
was running at hot summer-day without cooling finns or fan on grass
(that has been changed and now no problem)
i use a smaller motor than you will (only 230g weighting Lehner 1930)
so this should be of no problem for you
oh: i use around 2000mAh-2200mah in 10min
more measured datas (also with 4s, 3s and 2s) here:
http://www.kraeuterbutter.at/Bilder2...ono_Messwerte/
instead of increasing capacity on your batts, i would buy another set and change after 15min driving..
its like on helis.. donīt carry too much weight with you ;)
