MetalMan
MetalMan's Avatar
03.30.2007, 03:56 PM
Someone from Castle Creations might tell you the reason for the cogging is that you are using a motor other than the MM ESC comes with. CC says that the MM was designed specifically for their motors. For a while they've been working on an update that will allow all motors to run on the MM ESC (including Neu and Novak motors).
