ssspconcepts
ssspconcepts's Avatar
04.03.2007, 08:38 PM
Originally Posted by sjcrss
those are a set of gen II's, because i had a set of them at one time...and gen II's and III's both used the brass idlers.....however gen III's had stell pin inserts inside the 1st gear and 2nd gear...right where the shiftdog pins would make contact.....and yes they are the real deal
I bought a set of gears off of ebay for $100. I am not sure if they are genuine or not. The seller claims that they are titanium. Before you guys hang me out to dry and tell me that I have been had, please take a look at the attached pdf photo file. If anyone has any insight on special instructions and/or care that I should use to install them in my FLM tranny, please let me know. My biggest concern is how they will wear with the stock input shaft gears. Thanks for your time.
