Thread: Lvc ?
neweuser
neweuser's Avatar
04.04.2007, 09:12 AM
You should reprogram due to the new radio. But unfortunately, mine LiSaver did the exact same thing! What controller do you use? I reprogrammed mine last night and put in a new rx, seems fine for a short run......but not sure how much I trust it....with that said, reprogram, then have someone hold the truck and try it out before you let it go on it's own to be sure it works....also, make sure you get the distance measured too.
