04.05.2007, 02:07 AM
It's 100Amps continuous i believe. I think it should read as high as current as you can put through it until it blows up. It's just a heat issue i think, if you could mount it to a heatsink, the power throughput would most likely go up. It's mearly monitoring the power going through, there is no FET switching involved, so very little heat generated.
