glassdoctor
TEAM FUSION
glassdoctor's Avatar
04.05.2007, 11:49 PM
If you do A123's... you can always go 5s. You don't have to be stuck with the "factory" packs.
You will know what to do after you run the nimh packs... if 16cells is just right then do 5s... if 12-14 is enough for you then do the 4s....
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
